Active member
- Oct 13, 2023
- 378
- 201
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I received the same notice. Funny though — when I clicked on the “Product Safety Recall” link, I got an error message, “404 File or directory not found.” Sheesh!
IMPORTANT SAFETY RECALL
August 9, 2024
Clayton,
This notice is sent to you in accordance with the requirements of the Motor Vehicle Safety Act. This is to inform you that your vehicle may contain a defect that could affect the safety of a person. Our records show you have purchased an affected vehicle.
Polaris has determined that a loose ground connection for the winch may occur on some Model Year 2024 RANGER XD 1500 and Crew 1500 XD vehicles. A loose winch ground connection in combination with winch operation may pose a fire hazard and risk of serious injury.
Our records indicate that you are the owner of a Ranger with VIN xxxxx by Safety Recall R-24-02.
Polaris is currently evaluating a permanent engineered solution for this concern. At the time of availability, Polaris will notify dealers and reply to you by mail and
email. This work will be performed by your dealer at no cost to you.
As Polaris develops a permanent engineered solution, we are providing owners with information that will allow you to keep riding, by reviewing the following statement:
I understand that my vehicle is affected by R-24-02 Winch Ground Cable Safety Recall. A loose ground connection may occur in combination with winch operation, posing a fire hazard and risk of serious injury. Until the time Polaris releases a remedy for this recall, and it is performed, I should NOT operate the winch.
I wish that was it but I checked it. It is unlikely I will ever use mine so I just need to make a haul to the dealer before my one year warranty runs outlol. Maybe your ground is loose.
FYI: We just visited our dealer’s service department. Polaris still doesn’t have a fix for this issue.
August 9, 2024
Clayton,
Boy there's not much simpler than that!Good to know there is a fix.........but how did they manage to f*ck up grounding a winch?
Good information, I actually understand how that mistake was made and know what to check on mine.Here is what you need to do.
Thanks for the information, I will inspect and fix if needed today.There's a video link in the attached document
