rear end noise
nh 1500 owner
Dec 22, 2023
43
19
Anybody having a noise on rotation sounds like in the rear kind of like a clunking at low speed? Both in forward and reverse
Mine makes a noise when the suspension is flexing, sorta of a mild pop. I believe mine is the sway bar, no rotational clunking.
I had an issue when traveling at a constant speed (like 25 mph) and when I let off the gas, there would be a clunking sound. It would also happen accelerating. I took it in and they re-torqued the axle nut that goes through rear hubs. The noise is gone. They said it is a known issue on the 1500.
Thanks i think that may be what it is
