pueblogary
- Aug 3, 2024
- 55
- 20
- Thread starter
- #21
I took the rod off and used a D-shackle on the clevis pin, then connected the winch line hook to the shackle — see photo. The shackle is stainless steel that came from my sailboat.So I’ve been following this thread,and I’m getting the assumption that the winch doesn’t allow it to lift high enough, the vertical hydraulics don’t have the capacity and the tilt hydraulics aren’t long enough to tilt far enough to the right? Is all this correct?
I’m picking up my blade and mount tomorrow with the 2 sales that Polaris has going on. I didn’t want to pass it up.
As for the hydraulic angle, the hydraulic actuator shown in the other photo is working fine for me. It angles the plow fully in both directions. Someone else had an issue with theirs, but when I zoomed in on the actuator label it had a different part number.
