Absolutely I will do that. The aircraft is a super decathlon. One of the things I fly when I teach tail wheel and aerobatics.Avi8or, could you also measure before and after ride height? I can't lift my machine much more than the 32" tires gave me due to garage door restrictions and a wife who wouldn't appreciate climbing up another couple inches. Also, what are you flying in your pic? I don't fly much anymore but I buzz around in a 172 once in a while.
When we did the SDI E-Cliks, they had to mount in the outer shock mount holes in order to clear the frame.No difference that I could tell would matter. I got around to removing the rear Zbroz shocks this am and put the stock ones back on. There is no way for me to change orientation (without damage) to the reservoir and keep the bolt mounts where they need to be. Really hoping Zbroz will send another set that is correct and take these back. Wonder how this even happened.....
I know, wife was saying the same thing about my string of bad luck. Will update once I find out the solution.Man that sucks! Sorry for all the bad luck you’ve been having recently with fitment issues. Looks like everyone else had some of the same thoughts as I did. Swapping sides and or the outer mounts. I’m sure Zbroz will make it right or have another idea that we’re all missing. Fingers crossed for ya.
