🔖 It looks like you are browsing the site as a guest. By registering on the site you can participate on the Internet's largest Polaris Ranger XD 1500 forum. To register, simply Click Here!
Maybe a silly question but I have been unable to find a diagram of preferred jack points for this beast. I don't want to bend anything and I don't know how strong the skid plate material really is. Appreciate any information or diagrams you can share.
Not a silly question ar all. Someone may share an official Polaris protocol.
I just place the jack under the a arm with a piece of wood on top of it to reduce marring and offer a little better anti slip compared to steel against steel. Arched a arms has made this a little safer.
If in the garage I use the floor jackl placed directly under the front or rear end gear case. Very stable place and always steel framed. The only downside is you will lift one entire end of the machine and the suspension will decompress making you lift quite a bit before the tires leave the ground.
I always jack under the front or rear gear case as oneal said above. I have a Badlands Off-Road jack that has enough lift to do this, most floor jacks won't unless you use blocks of wood to increase the lift.
