I have a somewhat complex question I'm hoping someone has a valid answer to. I'm not looking for the " here's how I've done it and it's worked so far." type answers. I'm looking for a more specific answer. After selling my General, and upgrading to the 1500XD (three seat), I decided I should upgrade my trailer as well. My General on the single axle trailer was fine to pull all the way forward on my old trailer, tires against the rails. But my new trailer is longer and heavier. Its a 15' x 85" tandem axle. The mid point between the two axles is 13 feet from the hitch. I'm worried that loading the ranger (2900 lbs with full fuel) all the way forward will put too much weight on the receiver of the truck (2021 F-150 with a Class IV hitch receiver, which I understand is limited to about 1200 lbs tongue weight) So I'm trying to figure out how far forward to load the Ranger to keep it stable when towing, but still keep most of the weight on the trailer axles. Even if loaded slightly forward of the axles, I need to know HOW FAR forward, as I'm sure the Ranger is heavier in the rear than the front with the placement of the engine. I just don't know by how much heavier it is on the rear tires versus the front tires. Should I just get a hitch ball scale?
