Sub Install?
Hittman
Oct 22, 2024
7
Getting ready to install a sub under the back seat. I found the sub wires between the seats. Does anyone have the wire color codes, ie…positive speaker, negative speaker, remote wire?
Those wires hook to an amp. The factory kit is plug and play. Then from the amp to the subs.
I understand how they hook up…I’ve been installing systems for 35 years…I’m not installing a factory amp and will be cutting the wires. I need to know what each wire is, ie. positive and negative speaker wire and remote wire, which is usually blue.
You’ll need to find a wiring diagram. Even the install instructions for the factory kit, don’t identify the wires as to what they are
This the plug you are talkin about?
Might try a search here, someone recently done a great detailed right up on the subject
