Seatbelts Dig Into Neck
Susanna
Aug 3, 2024
26
9
Any idea how to fix the seatbelts digging into neck? Very uncomfortable and I hate not to use them when we are going down our steep drive, especially with hill assist on. No way to adjust that we can see. Saw some by IMMI that are for RZR and General. Not sure if they will work on 1500 Northstar.
I don’t think there’s a way to adjust the seat belts. But I do know there’s devices you can buy at an outlet parts store to reduce the angle of the belt that comes across the chest that should work for ya.
You may adjust the seat height and tilt to see if it changes the angle at which the seatbelt rests on your body.
You can buy seat belt clips on Amazon. Just pull out a little slack and latch the clips. The downside is the seatbelts won't retract unless you loosen the clips
