KC RANGER XD 15003
Is this a no no in the 1500 model#
Probably best to read the manual and decide the best path. It wouldn't hurt anything but is not required. Some here do, mine has almost 200 hours on the clock with 10% ethanol, runs fine.I was told by my dealer to use onlt ethanol free gas, nothing else.
Cant buy ethanol free fuel in Canada.I was told by my dealer to use onlt ethanol free gas, nothing else.
Well, that makes the decision an easy one, it's your only option. I think everything today is designed to run on at least 10% ethanol, that's what I run in my larger vehicles I think MN mandated 15% and there has been talk that Iowa may do the same. I'm sure if we go that route, they will still keep 10% and ethanol free gas, they will just charge more for it.Cant buy ethanol free fuel in Canada.
Same, if I use non ethanol, I have to let it warm up. And it’ll idle rough and even backfire if it’s not warm enough. Sometimes it takes a couple times starting also before it will stay running. I have non ethanol for the same reasons. But I’m gonna switch to normal pump gas and see if it’s any better. If so, I just might stick with that.I had a problem in cold weather when I first started my 1500 on 87 octane no ethanol. Had to let it warm up 5 minutes or so or it really ran rough. My next load of fuel was the winter blend 87 octane no ethanol. Made a big difference. Still need to warm it up some but much better. I use no ethanol fuel because of all my chainsaws and weed eater’s.
Yes sir, that is the way I understand it.The non ethanol fuel should actually run richer as the ethanol is a bit "thinner/leaner" I believe, is it not?
Found a bit of discussion here: Fuel: Ethanol vs. Non-Etahnol.
