Front Headrests
Sabaku
Received two 1500 front headrests. They go into the slots 2-3 inches and then won't descend any further. Any tricks or thoughts how to fully insert them.
Thanks
Still no luck there is a small hole on the setback do I need to insert something in there to get them to slide in?
No you don’t have to all that does is allow you to take the seat backs off a little easier. Which in turn you could see what the headrest is getting stuck on if you did take it off use a Phillips head screw driver in the hole
Seat Back Removal​
NOTICE
Parts of vehicle have been hidden for clarity.
  1. Push down on seat back cushion to remove.
    TIP
    If the seat back cushion does not release from seat back, pull bottom of seat out away from seat back and seat tabs.
  2. Push both tabs in and pull up on headrest to remove.
