do you take the outside skin off or the inside one?I’ve pulled a door apart to seal off dust incursion, but didn’t video the process.
But here’s a door breakdown from Polaris that may help you see how to do it.
https://www.polaris.com/en-us/off-road/assembly/?modelId=R24X6W1RBH&assemblyId=521905
The inside panels. The center, silver panel is held on by plastic clips, so you just gently pull on it to pop the clips loose. Then there’s a couple bolts under that, and the rest are visible around the outer edges of the inner panel. There’s a couple barb clips under the inner panel that will still hold it a little as well.do you take the outside skin off or the inside one?
