Factory Rear Work Light
RollTideSki
Dec 5, 2024
1
We installed the harness and work light per the instructions. The light comes on in reverse as it's designed to do but when I flip the 3 position switch to turn it on manually, it does not come on. Any thoughts?
Sounds like switch malfunctioning.Do you have a test light? See if the switch is sending power when you do it manually.
Like oneal said. It's a 3-position switch is there power going to the wires that go to the on position? I'm not sure what Polaris had pre-wired on the unit and what came with the light kit. Most of us had them installed at the factory.
The key must be on? Vehicle running? I know mine won’t come on if vehicle is off.
