Availability of 15 x 10" wheels for XD 1500
Mark
Jul 8, 2024
6
Greenbrier Ar
First post here and there seems to be a lot of knowledgeable members.
I upgraded to 32 x 10" BFG's when I purchased my Ranger but I want to run a 15 x 10 rim to get more footprint on the ground. I'm having a heck of a time finding those rims and the few I have I'm not sure if the offset will negatively effect the machine. The only wheel I've found is a Valor with a 4+6 offset.
I appreciate any feedback or suggestions on availability.
A 10" wide rim for a 10" wide tire is a very bad idea. A 10" wide tire should be mounted on a 7" wide rim, 8" would be the max. I never heard of anyone doing that nor do I think the bead will seal correctly. That said a 4/6 offset will move the inside of the rim out 2 inches from stock and the outside out 5" from stock! I really don't think you want to do that. If you want to run a rim that wide you really need much wider tires and I'm not sure that would be a great idea either. Just my advice others may have a different opinion.
I’m running the valor wheel and tire set up and I wouldn’t want to go with a 10” wide rim. The tires are nice and flush with the wheels. And wheels measure 15x7. Not sure if these pics will help with giving you a visual. But it’s all I have at the moment.
I’m running the same and agree. 32” valor alpha on 15x7 valor v09 beadlock
Appreciate your response. Sounds like even if the tire sealed the offset would be too drastic.
Yes, I feel the offset would be too drastic and really push your tire out further from the machine than you would like. The stock offset is a 6/1 which means 6" are on the inside of the hub and 1" is on the outside of your hub. I'm running 15 X 7" MSA Thunderlips that are very close to a 4/3 offset (actually a metric measurement) which pushed my tires out 2.22" on each corner making my Ranger almost 4 1/2" wider than stock. It gives the wheel a deeper dish look but does throw mud up the side of my machine. I hope this helps and you find the rim that works best for you.
