33” tires
Does anybody know if 33” tires will fit on my xd1500 northstar
I have 32 inch tires on mine and there is plenty of clearance. They don’t rub in any way shape or form. A lot of 33 inch tires measure less than 33, so they would likely fit under the official Polaris option. Polaris does say a 32 inch tire will fit and it is an option to upgrade to that. I think a true 33 would fit based on my 32 inch tires. Any larger than true 33 inch would have potential to rub on the front when turning. I know some have talked about doing a 35 inch (Kalon on the forum is doing 37’s, but with mods to fit) and I think there would have to be some modification to have 35’s work. Time will tell, as many are looking at larger tires.
What are guys using for the shock setting. Are you cranking them up a couple notches.
33's should work fine, as others have said there is plenty of clearance with 32's so another 1/2" will be ok. 505 Outsiders is running a 35" but those wheels do not look like the stock offset. I'm guessing those wheels are pushed out at least 2-3" which will make a difference.
33x10 System 3 XCR 350
Stock height and no rubbing
"33x10 System 3 XCR 350. Stock height and no rubbing"
Those tires look very nice on that rig, I don't know anything about System 3 tires but if they ride as good as they look, I would think many here would consider them.
So far the ride has been great! They are pretty quiet and don't feel super stiff. I still need to play with air pressure a bit but I've been very happy with them so far.
When you said stock height you meant for the shock correct. I would assume the top of the unit would now be 1.5 inches taller? Can you confirm or deny. stock height is 78". I ask because i'm considering an enclosed trailer and it's already tight at stock height. Any help you can offer is greatly appreciated.
By the way they look fantastic and I love the flatter wider stance on the tire. Did you get them online?
I meant stock suspension, no mods snd no adjustments. I gained a full 2" of ground clearance with these tires over stock.
I took a rough measurement of the highest point of the roof today and it was just over 80".
I bought them from KJ Motorsports but through Amazon.
